1 - 2 of 2 Posts
Hello
I have aquestion: I did record a dvd on my computer with a few HD movies from the camera.I used the HD option.
After I finished there was a statment that it will not run on most DVD's.
I tried to run it on my computer but I could't.
What shoud I do???
Thanks Yoni.
You'd need to know what format they were recorded in. If they're in AVCHD you'd need a BR player, if Divx you'd need a Divx compatible DVD player(or correct codec for your PC). What format are they in?
1 - 2 of 2 Posts
