  • If you've ever wanted to ask questions on industry standards when setting up your home theater, you're in luck! Peter Aylett, 30 year integrator and partner at HTE Acoustic Interior Design will be answering questions until Sun. Nov. 28th! The thread is now open, and you can join in here!
Status
Not open for further replies.
1 - 1 of 1 Posts
I am new to the scaler equipment. like to use the full range of my projector. I guess what i need is component out from megachanger into scaler and either component or dvi out from scaler into plv 70.
if i use dvi out i guess the scaler would need to be fairly close to the projector, since long runs of dvi are not good.
1 - 1 of 1 Posts
Status
