1 - 4 of 4 Posts
Premium Member
Hi,
I have been using DVDFab 9 to copy Blu-Rays to my server, and I am finding with DVDFab-9 it is taking about 1.5 to 2 hours. I would be interested in what speeds other are seeing and the settings they are using. I am using Copy Mode, Full Disc copy. I think one of the settings I may need to change is under the drives tab on the common settings window, I may need to change it from recommended to fastest, but I am not certain.
I want to maintain the full quality of the copy so I have selected on the Blu-Ray tab:
  • Enable full scan
  • Slow Speed / High Quality
Any suggestions / recommendations are greatly appreciated.
Bryan
What type of hardware are you using for Ripping?
I believe you need to set the settings for both audio and video to "Passthrough", thus enabling you to perform direct rips of the disc. I have an Dell Laptop with an I5 processor and 4 gigs of RAM and it takes about 45 minutes to rip a full disc, which also includes all audio options available.
The files will range between 30 to 45 gigs depending on whats included on the disc (Blu Ray - m2ts with Dolby TrueHD or DTSMA). DVDs should be about 6 gigs and should take about 20 minutes.
My results are inline with groove93's. 45 min to an hour for each BD, with "full disc" setting. I've never tired anything but full disc so I don't know if any time savings are gained by selecting only the main movie. As long as you have the BD 50 selection used, it will copy the full disc, untouched.
Any type of compression going on with the ripping process will take longer, no matter the hardware spec of your system.
1 - 4 of 4 Posts
