Hi all,
Relevent specs:
- Radeon 9600 with component dongle cat 3.10
- Lite-on DVD drive
- WinXP
- 1776x1000 resolution
- TT
- Latest version of DVDidle
- Extensive use of girder and DVDSpy
I only need DVDidle to remove the macrovision (no autostart, no region free, no dvd idling, etc.) and believe I have it setup correctly.
Problem: Whenever DVDidle runs (set to run on DVD insert) it turns off the autorun feature in the Windows registry:HKEY_LOCAL_MACHINE\\System\\CurrentControlSet\\Serv ices\\CDRom
1 = autorun ON, 0 = autorun OFF
Not only does it turn it off (changes 1 to 0), but it keeps it turned off even after it closes. This necessitates going in and changing the 0 back to 1 manually. The problem is that it not only stops programs from launching on insert, but it also seems to eliminate the possibility that windows, girder, TT can even tell that a disc has arrived. Obviously this is no good for a DVDSpy launched girder multigroup. I have confirmed this problem also w/ TT. Even if TT and/or autokiller is set to launch on dvd insert, nothing happens if the swtich is set to 0.
Is there a setting in DVDidle that causes this behavior and how do you turn it off? If not, is there another CSS stripping program (AnyDVD, etc) that does not exhibit this behavior?
Relevent specs:
- Lite-on DVD drive
- WinXP
- TT
