Status
Not open for further replies.
1 - 2 of 2 Posts
I was wondering if any progress has been made in supporting the Kenwood 400 DVD changer with DVD Lobby Pro 2.0. I am definitely just waiting for this feature to make my purchase.
I remember Mario had started on a crude program that did the basic startup routines of the changer but I don't see it on the site anymore.
Any help would be appreciated. Basically all I need is for the program to change to the correct dvd slot and start playing it. I can do the rest with my remote.
Thanx
what if you programmed a batch file similar to Bernie's that is posted on the Cinemar website? I think you would just have to figure out the sequence and timing of the commands for your paticular DVD changer. You would probably be able to reuse Bernie's DVD0001 - DVD0300 files.
1 - 2 of 2 Posts
Status
