Thinker,
Try using a negative number instead of a postive number to move the DOS window.
Also, are you planning on displaying the Movie Overview information? If not, you really don't need Profiler. Just put the dvd's in the dvdimages directory numbered as such. dvd0001.jpg, dvd0002.jpg, etc.
The current version although scales to any display, was designed to accomodate 16:9 monitors. Although, you could set a larger image for the background and it could cover up the bottom bar, but you would always have a top black bar.
