Status
Not open for further replies.
1 - 4 of 4 Posts
Are the following audio tests on DVE intended to check phase?
2 Band Limited Pink Noise - Half Left
4 Band Limited Pink Noise - Half Right
6 Band Limited Pink Noise - Half Right Surround
8 Band Limited Pink Noise - Half RS & CB
10 Band Limited Pink Noise - Half LS & CB
12 Band Limited Pink Noise - Half Left Surround
Discussion Starter · #2 ·
Any help folks? I was hoping DVE would have phase tests for a 6.1/7.1 setup since AVIA only has them for 5.1. Anyone familiar with DVE know if the following test are intended to verify phase
Yes, you can find tem on that disk.
1 - 4 of 4 Posts
Status
