DVI Blade for TH-37PWD6UY??
342 Views 2 Replies 2 Participants Last post by  alanortho
I am considering purchasing the Panny TH-37PWD6UY. I will have it hooked up to a HD TIVO receiver and DVD. Should I purchase the optional DVI blade ?????
Status
Not open for further replies.
1 - 3 of 3 Posts
alanortho, The problem is...
The TH-37PWD6UY comes with 2 slots only. And the Standard Supplied terminal (one-piece-blade) takes up both slots. So You'll have to remove the Standard Terminal to install the DVI blade.
http://gon5.audiogon.com/i/c/f/1072988517.jpg
Thank you. The literature makes it sound like you have these "extra" open slots to add some add'l features, but at least with the 37" model that is not the case. I would have liked to have the DVI terminal, but I guess I will go with the standard board.
1 - 3 of 3 Posts
Status
