Status
Not open for further replies.
1 - 8 of 8 Posts
I bought the $18.00 at pacificcable.com for my STB SIR-T351, it turn out very good.
Premium Member
Absolute no-brainer.
Either the digital cable delivers the 1's and 0's or it doesn't.
Signal quality and interference aren't even an issues like they
can be with analog signals. Get the cheap one.
Premium Member
Any DVI-D or DVI-I male-to-male cable will work.
Single Link will fit your needs, dual link will have
extra pins that won't be used for any current equipment
but may be used in the future (high def dvd players?)
and it's only an extra buck or two, so it's your choice
if you want to spend the little extra money to take
a gamble on "futureproofing" your cables.
I bought the exact cable you're asking about,
and mine works great.
Premium Member
The same holds for optical cables. Buy the cheapest ones you can find.
You're wasting your money if you don't.
An argument could at least be made that higher-end component cables
might perform better than some others, but I'm not one to make such
arguments.
Does someone else want to offer some brands for component cables?
Personally I tend to buy the "higher-end" RadioShack brand gold connector
cables for most of my A/V needs. (I put "higher-end" in quotes because
they don't really qualify as high-end, but they are the higher of the two
lines that RadioShack puts their name on.)
1 - 8 of 8 Posts
Status
