From the lindy.com website:
Premium DVI TFT/LCD Flat Panel Display Cable (DVI-M/DVI-M), 7.5m
These cables incorporate a second digital link (Dual Link) which allows resolutions up to 1920 x 1080!
DVI Digital Male to DVI Digital Male
For use with all modern TFT (Thin Film Transistor)/LCD (Liquid Crystal Display) Flat Panel Displays
Cables and adaptors are available from LINDY for the three most common video interfaces used today
EMC shielded - Patent pending RF-BLOK shielded design giving:
Reduced interference from one piece EMI/RFI shield
Increased insulation resistance up to 25%
No soldering requirements as interconnect design needs no 360 degree soldering - eliminating the possibility of human error and/or cracking of the solder that causes grounding intermittence and the use of the most hazardous waste material - soldering flux
Tight fit of internal wires as there is no inner mould
No requirement of ferrite cores as signal loss and degradation are greatly reduced giving enhanced signal sharpness. Without the ferrite cores the cable is less stressed and more flexible
Smaller overall dimensions which allows more room behind the host or peripheral
Increased connector and mating strength - the 4 point reinforcement tabs on the RF-BLOK, attached to the connector, strengthens the pair as one
Article
No RRP
VAT Incl.(£)
41244 26.75
Processing. Please wait...
http://pics.lindy.com/pics.nsf/0CBF0.../DVIM_DVIM.jpg
