Status
Not open for further replies.
1 - 3 of 3 Posts
I have just hooked up a Belkin DVI cable from my cable box to my Mitsubishi HD TV. When I change the channels now instead of just popping up it seems to flicker a few times before the picture pops up. Also, even after the picture is on for a while it will still flicker ever now and then like it is adjusting or calibrating itself. Does anyone know if this is normal ? Can I possibly have a defective cable ?
A little different set up but same thing was happening to me.
Sony KP51-WS500 with HTL-HD D* receiver. When I was going between channels with different input formats (i.e. 1080, 720..) and I had the output set to change according to input. When I changed the HTL-HD to upconvert everthing to 1080 this went away. Guess it just takes the receivers a second to adjust between formats and you get the screen flicker.
Discussion Starter · #3 ·
Tlove,
Thanks so much for the response, I will give it a shot and let you know the outcome.
Thanks again.
Jim
1 - 3 of 3 Posts
Status
