Status
Not open for further replies.
1 - 3 of 3 Posts
My Panasonic PT50-LC13 TV came with a DVI cable. However, I was looking at the connector, and each end seems to be missing a few rows of pins in the middle. What is the reason for this? Is this cable still OK for hooking up a DVI DVD player to the TV, or do I need to buy a new DVI cable with a full set of pins on the connector? Thanks for any help!
There are three sections in DVI cable, the dense pin sections may be only half filled. This means that it is a 'single' cable, when all are filled it is a 'dual' cable. Lastly there is a slot straight or crossed key on the far end and it may have several pins around it. If only the straight key is present it is a DVI-D cable and is all digital. The other pins are for DVI-I or DVI-A cable and provide analog signals and you must have this type of connector and socket (usually found on video cards), to use a low cost DVI-VGA adapter, such as the one sold by ATi for the late model radeons, as these work only in the analog domain. For what you have you should only need a DVI-D single, as this is adequate for transmission of all current HDTV modes and your Panny should have a single DVI-D HDCP connection that won't accept analog anyway. So if the cable is intact and working you are good to go.
good luck
1 - 3 of 3 Posts
Status
