Status
Not open for further replies.
1 - 3 of 3 Posts
Can someone tell me if the DVI-D cable needed to connect the HS10 to the DVI port on a Radeon 9000 pro is Single Link or Dual Link type. And where can I get one at 6 or 7 metres in length either in Australia or that can be shipped there.
I just setup my HTPC using DVI to my Sharp M20X projector with 7 meter cable. I ordered a 5 meter dual link DVI-D and then a 2 meter DVD-D extension cable. I was warned when I ordered it that DVI spec is only up to 5 meters, but I took the chance anyway, and it works great. In my setup it looks noticeably better than the analog VGA.
1 - 3 of 3 Posts
Status
