Please do a search before posting. this question has been answered over 100 times already. Here is the answer again, Yes, BUT ONLY if your 3250HD has the newest version of the software the box runs on. anything older, such as the original software doesn't support DVI. Check with your cable company to see if DVI has been enabled. Your TV MUST also support HDCP on the DVI connection or you will get no picture. you can not upgrade the software on the cable box yourself, this is something the cable company, and the cable company only can do!
