Status
Not open for further replies.
1 - 3 of 3 Posts
Any one have a more economical alternative to the overpriced $100
monster cable dvi hdcp cable? Will a Dvi-D cable work?
Thanks!:confused:
hi bdfox18doe
I did an AVSforum search on "DVI cable" a few days ago and found a lot of interesting threads. Here is a link to a tutorial at:
http://www.pacificcable.com/DVI_Tutorial.htm
There were many testimonials that www.PacificCable.com made good cables with good customer service and the DVI-D dual link 2 meter cable is around $20 plus shipping.
www.bettercables.com - a sponsor of this forum - also makes a 2 meter DVI-D dual link for about $70. From looking at my TV (Sony 34xbr800), it appears to require a male DVI-D dual link cable but the tutorial should help clear up what you need for your display.
Hope this helps. Good luck. :)
Rick
Discussion Starter · #3 ·
Thanks! Will take a gander at that~:)
1 - 3 of 3 Posts
Status
