Howdy all ...
I did the search ... i did the home work .... now i have conflicting information.
??? Can I hook up a Geforce 4 (DUEL DVI) to a HDTV (JVC AV56WP30) using a dvi cable ??? and run greater than 640X480?
the quote i got was that DVI/HDCP is "DVI 2.0" and a computer only outputs DVI "DVI 1.0".
Reading till 2:30 AM last night i kind of thought DVI/HDCP is the same as "DVI-D" with a little something extra added in to keep you from copying it. therefore you can input DVI-D into it and the "CP" (copy protection) wont do anything.
so what do yall think ?
thanks,
[email protected]
thanks,
[email protected]
