Status
Not open for further replies.
1 - 4 of 4 Posts
I was asking in the computer section, I need a 25ft VGA cable to connect a PC to my Sharp XV-Z2000 projector... the VGA cable is simply so I can surf the net and play MP3's and have the windows media player graphics on the big screen... I'm not going to play DVD's from the computer and am not concerned about quality resolution whatsoever... as such, several recommendations were made on where to buy a 25ft VGA cable, all were well under $50 bucks... cool :)
I also recently bought a 45ft Silver Serpent Subwoofer cable for like $184 bucks... and was told that I could have gotten a way cheaper sub cable and had just as good a quality....
I'm currently looking for a 25ft DVI-HDMI cable to connect the projector to my Denon 4806 projector... This cable is the lifeline of picture quality.
I've found DVI-HDMI cables at 25ft anywhere from $50 bucks up to $200 bucks... I dont want to get bent over again for cable if I can get just as good a picture quality from a less expensive cable.
I'm new to all this stuff... what and where would you recommend for a 25ft DVI-HDMI cable?
Mark
Discussion Starter · #2 ·
I also need a 25ft Component cable.... what do you think of this one from pccables.com for $18.95?
"These work as good if not better than cables costing 100's of dollars."
http://www.pccable.com/images/02422.jpg
http://www.pccables.com/cgi-bin/orde...les.com&rcode=
This Component cable is $91 bucks from BlueJeans:
http://www.bluejeanscable.com/store/...t/7710vert.jpg
BlueJeans also has a 23ft HDMI-DVI(D) cable for $66 bucks:
http://www.bluejeanscable.com/store/dvi/dvicable.jpg
I dont mind spending $300 bucks for a HDMI-DVI cable if its worth it as this is the main artery of the projector... so what would you recommend?
Discussion Starter · #3 ·
I'm thinking about this cable from pccables.com: 30ft HDMI-DVI cable for $58.50
http://www.pccable.com/images/01719.jpg
HDMI to DVI digital video Cable Interface Connector.
Connects components of the two formats for highest-quality HDTV picture.
Features:
# Standard Gas Dielectric for maximum signal strength
# Triple-shielded Design with Dual Ferrites for maximum rejection of RF and EM interference.
# Gold Plated Contacts.
# Transfers all HDTV formats including 720p, 1080i, and even 1080p.
# Silver-plated pure copper conductors for Superior conductivity and Maxiumum Bandwidth.
Usage:
Connect HDMI Displays (TV Flat) to DVI Components
or HDMI Components to DVI Displays (TV or Flat)
Including Plasma LCD and Other Displays Like Computer Displays with DVI Inputs.
Get The Best HDMI - DVI Cable at Discount Prices at PCCABLES.COM.
Discussion Starter · #4 ·
monoprice.com has this 25ft gold plated HDMI-DVI cable for $29.65
http://www.monoprice.com/productmediumimages/21211.jpg
25FT HDMI Male to DVI-D Male CABLE for HDTV PLASMA DIGITAL VIDEO
High-Definition Multimedia Interface (HDMI) is the first industry-supported, UNCOMPRESSED audio/video interface.
Transfers at rates up to 5 Gbps!
This cable connect DVI devices to HDMI devices for DVD, satellite boxes, LCD, projectors, plasma and HDTVs.
HDMI is fully backward-compatible with DVI that handles digital data transfers at rates up to 5 Gbps!
HDMI provides an interface between any HDMI-enabled audio/video source, such as a set-top box, DVD player, and A/V receiver and an audio and/or video monitor or projector.
HDMI supports standard, enhanced, or high-definition video, plus multi-channel digital audio on a single cable.
It transmits all ATSC HDTV standards and supports 8-channel digital audio, with bandwidth to spare to accommodate future enhancements and requirements.
What is AWG?
American Wire Gauge (AWG) is a U.S. standard set of non-ferrous wire conductor sizes. The "gauge" means the diameter.Since thicker wire carries more current because it has less electrical resistance over a given length, thicker wire is better for longer distances.
LCD projectors? I'm guessing it doesnt matter if I have a DLP projector?
1 - 4 of 4 Posts
Status
