Status
Not open for further replies.
1 - 4 of 4 Posts
I'd like to run DVI both from my HTPC and from my HD STB to the ONLY DVI connector that I have on my TV.
My questions are:
1) Is this a good idea?
2) If so, what switch would you recommend for ease of use? I'm looking at this switch that will allow you to do it via keystroke on the HTPC: http://www.uniclass.com.tw/products/DVI_KVM/UDV-002.htm
I'm thinking that if this DVI switch works well, I can easily change between the HD STB and the HTPC - even program it to the remote control.
My only affordable alternative is to purchase the component dongle from ATI to my 9600 Radeon and use it with the set or run component from STB to the set.
I'd prefer to maintain DVI for both the HTPC and the STB into the TV. :D
Any other suggestions? Thank you.
1 - 4 of 4 Posts
Status
