I have a x850 XT with the current catalyst control center and drivers. My TV is a Panasonic TH-42PX80U.
I have a DVI to HDMI cable (25ft) going from my DVI port to my TV's HDMI port. Whenever I turn on the TV and the cable is connected and resolution / monitor enabled I get a no signal found error. But when I turn on the display and then enable my second monitor with the same resolution settings the display works correctly!
It is a pain to have to manually enable the monitor every time I want to use the TV. I have not been able to figure this out for a while and am last posting here for someone to hopefully have had this problem before / know what is going on.
The resolutions I use do not matter, it happens for all of them. The TV works fine on that port with a xbox 360 its just this computer that has the problem.
