1 - 5 of 5 Posts
I'm trying to hook up my Comp to my Projector via DVI to HDMI cable, but I'm not having much luck.
My graphics card is a Radeon 9800se-Catalyst Driver version is 6.14 and my projector is a Panasonic PT AX100E.
The Graphics card detects the projector,but that's about it.
It says that its a clone display, which is what I'm after but I'm not getting any signal.
I can use a DVI to VGA cable on the projector and that works fine, but I would like to get the DVI to HDMI link up & running.
Any suggestions would be appreciated.
Premium Member
I use Hydravision (on ATI website) to utilize my projector via computer. Set second display to resolution of projector.
1 - 5 of 5 Posts
