Status
Not open for further replies.
1 - 1 of 1 Posts
· Registered
Ok, my 9800pro had VGA output, and it worked great when using that with my Mitsubishi WD-52725.
I replaced the 9800pro with an nVidia 7800GTX about a week ago, and I am not having a good time getting my mits working with it. The card has 2 DVI-I outputs, and it came with a basic DVI->VGA adapter. When using that adapter and turning on the mits, my computer recognizes a second display is connected, and I set the computer to make that second display clone the first one. However, the mits won't display anything. When I reboot the PC, I can see the BIOS screen load up on the Mits, but as soon as Windows boots, there is no signal. I am keeping the resolution at 800X600 for testing purposes, and still nothing.
Does anyone have any tips for getting this display working with the new nVidia card?
1 - 1 of 1 Posts
Status
