I just got the Fusion HDTV II card for my HTPC (2.66Ghz P4, 512Meg DDR333, Radeon 9200) and I have it connected to my NEC LT150 projector which as a fixed-pixel resolution of 1024 X 768.
480i shows will not display full-screen, 1080i seem to work well, but 720p broadcasts are very jittery. The whole screen freezes every few seconds. It's more jittery if I turn of DxVA, but it doesn't freeze, but if I use DxVA, it is smooth until it freezes.
The signal strength indicates 100%. I'm line-of-site from the broadcast towers, so that's not the problem.
I called digitalconnections.com tech support and was told that I need to run Powerstrip because 720p is not 1024 X 768. I don't know diddly about Powerstrip or how to use it, set it up, or if it's even necessary for this.
I thought part of the benefit of the Fusion HDTV II card was that it used the HTPC's video card and could scale to whatever resolution you needed.
Help! Please!
-Tom
Help! Please!
-Tom
