1 - 3 of 3 Posts
· Registered
Hello
I got this unit from a very good friend of mine as he moved on to a better
projector.
It has a nice picture but on the right side of the screen , a 2 inch wide vertical strip of the image has some artifacts showing.It runs all the way down.
Any ideas ?
thanks
· Registered
Hi John,
Did you try image position (L/R) and image width in the various menu options? Depending on which input is selected, you can shift it left or right and/or expand it wide enough to cover the artifacts. Some inputs don't have the option though...
-Ken
· Registered
Originally Posted by Ken Moore /forum/post/16958494
Hi John,
-Ken
Doing this is not good for the video processing.
Does this occur on all sources and all inputs?
1 - 3 of 3 Posts
