41 - 60 of 51962 Posts
Originally Posted by AudioArchitect /forum/post/0
The Contour 3.4's are awesome speakers.
I am curious though how did you come by Primare equipment. Its good stuff but just not a typical pairing I have heard of.
Primare is a danish/swedish company.
Over here in Sweden Primare it´s still exotic but not as exotis as it would have been in the states i guess.
The Spa20 reciever is considered powerful when compared to other recievers, but it costs more compared to others too... Very basic, very heavy 23kg, compact, no gadgets, very warm, consumes 70 watts in standby mode, quite stylish if I may say so. I think it drives the contour s 3.4 very well! Primare is quite often recommended when you have powerhungry speakers and need a multichannel integrated amp. Sound is transparent, bass very quick and deep. Upper register is soo much better then my old bi-amped Cambridge Audio setup.
Not sure here but I think the new contour series is a little bir less powerhungry when compared to its predecessors
Anyone here that has experience on the centerspeakers in the contour s series? Could I go with just any centerspeaker in the Contour series? Even the older ones?
Well, I've always been an B&W fan for home theater but recently was shopping around for some small powered bookshelfs to do music duty for my home office. I think B&W's somewhat forward sound and metal dome tweeters work great for home theater but not so well for non-fatiguing music listening. I also didn't want the bulk of a pre-amp and separate power amp for the office so I had intended on listening to the Mackie HR824 studio monitors. While I was auditioning them I noticed Dynaudio had a small powered bookshelf mini studio monitor. I flipped the switch to listen to them and my God, I literally fell out of the damn chair when I heard piano jazz playing through them. Best of all, they were cheaper than the Mackies. They do not go extend quite as low as the Mackie's with their smaller woofer but in terms of resolution and imaging, I've never heard any speaker as good as these at this price point. I'm not sure how Dynaudio can afford to sell these things at $1,000. It's honest to God, a bargain considering you are saving money by not requiring a separate amp. I had never really considered Dynaudio before listening to them in Guitar World of all places. I'm amazed over and over again that something this small and reasonably priced can sound so good. They represent an even better value than Dynaudio's consumer Audience line and appear to use the same drivers (someone correct me if I'm wrong) They can also play quite loud without distortion, up to 115 db short-term. The tweeter seems to do an amazing job of being highly accurate and detailed without being fatiguing like my B&W 603s. If Dynaudio puts this much workmanship in their entry level studio monitors then I can only imagine how nice their other product lines must be. Since I use them on my computer desk I trim the midrange frequence switch down two decibles otherwise you get somewhat of a spike from the sound bouncing off the surface. This seems to flatten things out quite nicely.
One thing to be aware of though, is these have balanced connections only, so you have to either buy an XLR to RCA adapter to run sound from the source. I purchased a small Behringer mixer for about $50 that seems to not add any color to the sound and does a fine duty of being a small preamp.
If you are in the market for a small powered mini monitor that sounds a lot larger than it is, check Dynaudio BM5A out on their professional studio monitor website.
The BM5A's have the Esotec D260 tweeter, which is different from the ones in the non-SE Audience series. The woofer is a 17W75XL I think. If you already have a good amp, the passive version, the BM5 Mk. II is out. It's good that you like the sound right away. It took me a while to get used to my monitors, but I like them now. Not as many people know about Dynaudio Acoustics, the pro audio division, but they make some really serious speakers higher up the line, like the Air 6, the Air 25, and the M3 (with the Esotar T330D's).
While you were at the store, how did the BM5A's compare? They have some healthy competition at their price point. For $1000 you can get the Mackie HR624A, the Event ASP6, and the flavor-of-the-month Adam A7's with those interesting Heil drivers. And then there's the passive BM15's for ~$1100.
Discussion Starter · #45 ·
The Contour SC matches tweeters with the 3.4's
The Contour SCx has the Esotar2 as found in the 5.4 and the Confidence line.
I find that most Dynaudio center channels work well with the mains because the motor structures of the woofers,midranges are very similar. The tweeters never draw attention to themselves unlike many speakers so as a result you can mix models with relative ease.
As far as amps go. I agree and disagree with the Primare. It is a high quality amp so it will make good music, but you can extract even more out of those speakers. Try a high powered offering from Bryston and then will sound incredible!
Yuriv:
I listened to the Mackie's (which I was pretty set on buying) and that's when i listened to the Dynaudio monitors right next to them. To put it plainly, there was no comparison, yes the Mackies could go slightly louder and have a lower bass extension, they just sounded muffled in comparison and not nearly as open. I literally fell out of the damn chair when I heard piano jazz played over the Dynaudios the first time. It had so much presence and felt so tangible and I've never had this reaction from a loudspeaker. And at their price point I'm surprised Dynaudio doesn't market these at their home consumers as an active monitor with an unbalanced input instead of a balanced XLR input. It would be an incredible value.
Yuriv,
I believe the regular Audience line have the Esotec D260 tweeter. The SE have the Contour S model tweeter according to dynaudiousa website.
I found this on Dynaudio website regarding the Audience 122C:
A newly developed tweeter and updated crossover network further improve performance. The 28-mm soft-dome tweeter is a shielded version of Dynaudio's renowned D260 ESOTEC tweeter and features a 4-mm die-cast front for maximum stiffness and a vented pole piece and rear chamber for excellent transient response. Working with the tweeter are two special 15-cm ESO-TEC woofers with 75-mm aluminum voice coils and one-piece molded diaphragms.
You guys are right and I misunderstood this statement. After reading this again, it looks like it's a new tweeter that is a shielded version of the D260.
On their web site, it's not clear that all of the non-SE Audience series speakers use the D260. I can see why they would want a different shielded tweeter for a center channel that could be close to a CRT. Here's what they actually say for some of the other ones:
The Audience 52 features a 75-mm aluminum voice coil and one-piece molded diaphragm in a 17-cm woofer that works with a 28-mm soft-dome tweeter providing clear, detailed and dynamic sound reproduction across the entire frequency range.
Audience 82 The 28-mm soft-dome tweeter is an improved, customized version that incorporates many of the features of Dynaudio's renowned D260 ESOTEC tweeter. With a 4-mm die-cast front for maximum stiffness and vented pole piece and rear chamber for excellent transient response, the tweeter also utilizes magnetic fluid for exceptional power handling and damping.
There are some sources online that say that the Audience series tweeter is actually a variant of the D28/2, which is also very good. Some people even like it more than the D260. As you noted, the SE series have the new Esotec tweeters, which is newer than the D260. Their 17W75LQ woofers are nicer too.
My speakers came with one sheet that has a section that says spare parts references Please quote these references when ordering spares. It lists the replacement drivers and their part numbers. If yours came with a similar sheet we can find out what part it really is. The section continues, If you have trouble obtaining parts from your local dealer please contact Dynaudio
There are at least two dealers among us, right? Maybe they can look it up. Specifically, I want to find out what's in the regular A52, which I'm thinking of getting for one of my bedrooms. I've heard them before but I still want to find out about the drivers and how they compare to the BM series monitors.
Hi I just ran across this thread. I have a 5.1 Dynaudio setup as follows
A pair of Contour 3.3's for my mains
Contour 2.1 center
pair of Contour SR's. I went with these because the are much smaller than the 1.1's
2 Velodyne SPL=1200Rs
Powered by a Aragon 8008x3 and a 4004
Anthem AVM-30
I am extremely pleased and probably won't make any changes soon
Hi,
Im about to upgrade my speakers, and I liked what I heard from Dynaudio. I have a couple of questions:
1. I´m choosing between Focus 220 and Contour 3.4. I can have them both for 2000USD a pair, Focus 220 as a dealer demo and Contour 3.4 ca 2y old from a single owner privately.
I´m using a Marantz combo, AV9000 prpcessor and MM9000 5.1, 5x140w 8ohm amp. Will that be sufficient to drive Focus 220 or contour 3.4?
Is it, with regard to power amp, preferebly to choose any of the two speakers?
And, finally, any words on the difference between 220 and 3.4, regarding quality?
regards/Pat
Originally Posted by patjoh /forum/post/0
Hi,
regards/Pat
Both are great speakers. Having said that I would get the Contour 3.4's for the same price. I would think that your amp will run both speakers just fine. The focus 220's are probably a little more efficient than the Contours. Both speakers are 4 ohms and I believe your amp puts out 200 to 240 watts per. That should be plenty for the 220's but the 3.4's, the Marantz might run out of steam if you push them very hard. The best is to listen to both before making your decision.
Welcome me to the club!
Today I will be purchasing a pair of Focus 220s a pair of Focus 140s, and a Focus 200c. I have been listening to various things (Paradigm, B&W, NHT, MB Quart, Energy) for a while, and last night I brought the wife with me to confirm what I already felt I knew... that the smaller and more elegant Dyns were worth the extra $1000 over the equivalent Paradigm Studio setup.
For the time being, my Focus speakers (which will be Cherry), will be in a 5 speaker setup with no sub and no rear surrounds. They will be driven by a Sherwood P-965 pre/pro and a Sherbourn 7/2100 (7X200, but 7x300 into 4 ohms) amp.
I am living in a smallish rental house in So. Cal for another two months before moving back to the Bay Area. I'll have to wait until I get back there, and see if I'll be able to dedicate a room to my theater before I pick a sub and back surrounds.
In any case, I continue to be floored by the clarity, detail, and (most of all) the imaging and staging of the Focus 220s. Again, on my final audition last night, I was amazed and moved by the uncanny "that singer is standing right in front of me" sensation. This is a bit more than I originally planned to spend, but they sound so much better than anything else I listened to (I resisted the temptation to hear the $4000/pair Revels), I feel happy to be blowing my budget.
I've been told I can expect to receive my speakers mid next week, and we're going out of town on Friday, so I'm looking forward to the speakers spending all of memorial day weekend playing constantly and getting a good jump on my 100 to 200 hours of break in.
Thanks to the board for helping me decide, and I'll look forward to writing again soon, when the Dyns are in the house!
Welcome to the club Jeff!
I know and thats thrilling. In the future I would like to try the NuForce Reference digital amps to my fronts. But first I need a matching centerspeaker.
Du you know if the older Contour series centers will match also? They are substansially cheaper and seem very well built also although not so goodlooking as the contour s centers.
JeffNebraska,
Congratulations and welcome to the club. We all had similar experiences as you did when comparing Dyns to others.
Enjoy,
Vin
When I went in to order my Dyns, the guy I'd been working with was busy with some other customers for 45 minutes or so. I decided to hang out in the store's dedicated theater and watch Pearl Harbor (which I'd never seen... really cheesy garbage).
After waiting about twenty minutes, he said to me, "sorry this is taking so long, I'll give you a better deal since you've had to wait." When he rang me up, he gave me 20% off the list prices, rather than the 15% he'd been promising.
I'm sure others have gotten better than 20% when ordering a five speaker package, but since I was prepared to only get 15%, I felt like I was getting paid $300 just to watch a movie on an incredible system. It made the purchase that much sweeter.
i currently have the 52se and recently got the 122c. I havent experimented with it much..but so far its been pretty good. running test tones...52se's definitely have a different tonal color from the 52se but during movies...its not so noticeable.
Im trying to look for rear speakers (or sides in my case...sofa against the wall). Now im looking for dipole/bipole switchable speakers which unfortunately Dynaudio doesnt have...(not even regular dipole or bipole). I would like the rears to be switchable dipole/bipole for convenience when switching between music (cd/sacd/dvd-a) and movies. Ive ruled out monopoles (52's or 42Ws) since i dont think i would like the "obvious" presence of it during movies.
My choices are the following...
Polk LSIfx
Polk fxi300 or fxi500
Infinity Beta ES250
Aperion intimus 534
any one used any of these with their dyns?
Dynaudio doesnt get much attention here, but it is very exclusive and as such not readily available in all states. As the exclusive Dynaudio dealer in San Diego, we represent their speakers as the state of the art. If you want to leave nothing to chance and simply want the most accurate performance Dynaudio is the ticket. In an industry where you can easily overpay for underpeforming equipment, Dynaudio has always been about no compromise speaker design regardless of price. After listening to the Contours in our showroom, I immediately knew that my next speakers would be the Contour S5.4....still saving.
I would love you to hear from all you Dynaudio owners out there, and what kind of gear that you pair up with it.
I plan on getting S3.4s and running them with a Krell 400Xi (simple sytem yet great imaging) early next year. Please answer a few of my questions.
1. How much difference is there between s3.4 and Focus 220?
2. How much difference between s3.4 and c1 (price is similar)?
3. Has anyone used or heard digital amps such as PS AUDIO's GCC100 with Contours or above?
4. Since you are a dealer,just how BIG is Dynaudio worldwide. One dealer told me they are the same size as B&W,is that true. Just wandering.
5. What would be the B stock price for s3.4s ? On Audiogon, they go for $2500-$3500.
Thank you for taking the time to answer my questions. A good CD to play on Dyns is Donald Fagen's IGY from Nightfly............speechless.
Premium Member
I've been in the Dynaudio club for a while now:
Contour: 3.4 front, SC Center
In-wall IP-17 rears (used for EX rears for movies and as the surounds for DVDA and SACD).
Paired with these are Paradigm Studio Reference ADPV2 Surrounds (I prefer the diffuse surround to the direct surrounds for movies, but Dynaudio does not have these) and a Velodyne HGS-18 sub.
Components:
Anthem Statement D1 pre/pro
Sherbourn 7/2100A amp
Arcam CD192 CD player
Denon 2200 DVD player
Velodyne SMS-1 subwoofer system
The DVD player will probably be the next upgrade.
The sound is great!
Mike
