Originally Posted by
moshock /forum/post/15605470
I ended up pulling the trigger on the Dynex, couldn't be happier. Here is some information I posted regarding this display.
This and more information can be found here:
http://www.avsforum.com/avs-vb/showt...039018&page=23
Pros
Absolutely no glare on the bezel
Absolutely no glare on the screen
1080p capable
Accurate colors after calibration
Easily accessible service menu
Ability to lower backlight to increase PQ and reduce power consumption
Deeper blacks than my plasma
Functions well with universal remotes
Inexpensive extended warranty option
Best Buy brand (they will exist the entire duration of the extended warranty)
Cons
Visible pixelation and artifacting within 5 feet (Solution: Sit ~10 feet away, where you should be sitting with a 42" TV)
Minor motion blur (I can sense motion blur on nearly every LCD though, and this isn't any worse than $1500 LCD's, sooo...)
I paid $629.99 for this TV and bought the $99.99 4 Year Extended Warranty. At that price, or even hundreds of dollars more, I wouldn't recommend any other TV than this. This set is truly beautiful after taking the time to configure it properly. IMO, it looks as good if not better than my friends' Sharps, Sonys, and Samsungs, and they all paid $1000-$1200.
Here is my exact panel information:
- SW Ver: SL42HV40-10A1018T
- Panel Info: 420H1-L05
- Software Build: 07/05/08 11:44:59
Note: I watch mostly 1080i DirecTV HD over HDMI. After plenty of tweaking and using DVE and the THX Optimizer, here are my settings:
HDMI Settings (Best as of 1-19-09):
Contrast: 75
Brightness: 46
Color: 56
Tint: 0
Sharpness: 30
Color Mode: Cool
Gain Red: 123
Gain Green: 126
Gain Blue: 108
Offset Red: 125
Offset Green: 125
Offset Blue: 125
Backlight: 50
Noise Reduction: Off
XVS: Off
