Status
Not open for further replies.
1 - 6 of 6 Posts
Has anyone noticed a shift towards red when going to
HD HBO? Any ideas, solution? Thanks
Premium Member
I just had the color decoder in my Mits 65907 adjusted (to control red push), and yes, I believe that the 6000, as well as the PVR 501, both have slight red push. I've also noticed a bit of Y/C delay error as well in the 6000.
J.Mike
I am firm, you are obstinate, he is pigheaded
My DVD Collection
My Home Theatre
I've only had the 6000 several days but notice and adjust for the excess red.
Discussion Starter · #4 ·
I use a G70 and so have no access to controls other
than for brightness and contrast for HD. The SD
signal goes thru a scaler that does allow adjustments
for color, hue, sharpness. Am I stuck?
Also, has anyone noted more softness and lack of detail
in the dish signals. ? compression/bandwith problems.
Is Direct better?. If so, some of the combined systems
approach may be best. Ideas?? Thanks.
hmars,
That was the primary reason I switched back to DTV. I too noticed more softness in the picture on Dish than that of DTV. Keep in mind that I am certainly not saying the average DTV (non HD) channel is sharp!
After several days with dish, I would agree that it is softer than DTV but with fewer artifacts. I find it better to zoom on the picture than DTVs pic on a 34" screen.
1 - 6 of 6 Posts
Status
