Status
Not open for further replies.
1 - 9 of 9 Posts
I get a picture on my XG 110, but no test patterns. I swapped the system PWB board and it works good. I was told this was a problem with the E-prom chip. Where can I get another board or chip or can this be reprogrammed? Also should I try swapping chips to see which one it is, which one should I check first.
Thanks, Deron.
Discussion Starter · #2 ·
Burp
Oops, excuse me.
Deron
Deron,
Not to state the obvious, but have you first tried pulling any chip in a socket and re-seating it? Sometimes you get lucky before swapping parts.
Marc
Discussion Starter · #4 ·
Marc
I will try that.
Thanks, Deron.
Doug, do these units remember that? I was under the impression that the OSD usually defaults back to on. Am I nuts?
Marc
Discussion Starter · #8 ·
Doug
Thank you.
You hit it on the nose, fixed the problem, I'm back in operation.
Deron
Well, that proves that the CPU remembers the last OSD state. Good to know.
Marc
1 - 9 of 9 Posts
Status
