-Panny E100 setup to record in high speed mode.
-Recorded a 2 hour movie on the HDD.
-Set markers at specific points in the movie.
-Did a high speed dub which was working fine in high speed record.
-Close to the end of the dub, the E100 had an error.
-Removed the blank DVD and found it had a smear on the recording surface close to the outer edge. My fault for not insuring the DVD recording surface was clean.
OK, popped another blank DVD disc in and started the dub again. But this time it started dubbing in realtime mode and took 2 hours to complete. All of the markers I had inserted were not on the disc and only the default every 5 or 10 minute (did not time it) markers are on the disk.
If the first high speed dub fails, is the second high speed dub always realtime? How can I do a second high speed dub if something similar happens again?
