I have started the process of conversion of my home movies onto DVD RAM. The following is the process I am following but am wary of 'gotchas'. I would appreciate any warnings or suggestions for the more experienced users.
My plan is largely a batch process:
1. I am putting all my VHS tapes on the HDD at SP speed
2. I am reviewing each, adding markers and shortening segments as appropriate. Side note: I had no idea how many hours I had spent in dance recitals.
3. I am then using 'Divide Program' to establish my timing and arrangement for RAM burning.
4. Make the RAM master copies via HS burn.
5. Use a DVD burner to make multiple copies. At this point, I believe the basic editing capabilities of the recorder are good enough. Eventually, I will use the pc for highlight type editing, but not now.
Any suggestions for a better process? I am really in step 1 and 2 which I am doing concurrently.
Mike
Mike
