OK, check this out. If you carefully take the fiber optic ring out, you can then tape with black electrical tape and cover the ring lengthwise. If you go all the way to the ends, you will have a very dim light.
The ring fits just barely inside that metal housing and is only attached to the bottom of the cup holder with a very small amount of glue. I have 6 six seats and half were barely glued at all.
With a bit of experimenting you should get your desired results. I tried the black craft paper idea, and although it worked, I did not like the finished look. This works and you can't tell I did a thing to the cup holder. You can even try taping different sections or lengths to see what you like.
