The idea with HPTC's is to REDUCE power consumption, not squeeze every ounce of performance out a processor.
Hi Guys, this is Barry here w/ CoolIT. Just based on those stock clock, temperatures something is clearly wrong and I suggest you return your ECO on RMA Yozz.
We've got a 920 here so I will set it up w/ an ECO on it and report the temps back here later.
We designed the ECO to beat the H50 and that is exactly what it does. Not sure what is going on atm but we will get to the bottom of it and report back.
To all that were helping assist in this thread. Greatly appreciated.
Quick heads up guys, a random ECO pulled out of the last shipment we got is keep an i7 920 is in the low 50's at full load, stock speeds.
They are doing runs at 3.8, 4.0 and possibly higher now.. will keep you posted.
Originally Posted by Nimo /forum/post/18112731
less heat means longer life cycle for your hardware.
Originally Posted by Suntan /forum/post/18114391
Not really. Unless you are really cooking the thing beyond its design temps, less heat doesn't really mean much. It's just one more number that gearheads can compare to show off their E-dork machismo.
Honestly it is heat cycling that puts strain on the traces of circuits. Once it is up to steady state, there is little to no wear on it, unless you are cooking it to the point that the individual materials are breaking down.
Has anyone had a CPU, kept at a relatively sane but by no means cool temp, die on them before it was completely outdated and useless?
Regardless, if you like the cooler and it suits your needs, have at it. Personally, I don't think I would ever bother with water cooling in this day. CPUs are just too robust and efficient now to have a need for the complexity.
-Suntan
Originally Posted by stanger89 /forum/post/18113879
It's not going to make it "much" cooler. These exotic cooling systems really only become usefull if you've got a component (processor) throwing off lots of heat, so much heat that more standard solutions can't effectively remove it.
I've never understood going to water for silent cooling, they've still got pumps and fans that make noise (not to mention more stuff to fail). The way you get silent cooling is with heatpipes and massive heatsincs.
Originally Posted by shayking /forum/post/18118232
we, should no better than to talk about Liquid cooling at the avsforum.![]()
Originally Posted by AnthonyB /forum/post/18119375
First of all. You MUST do a 48 hour leak test before you put your components in there
Second of all, there is another 48 hour test with everything but your motherboard plugged in and hard drives powered up.
