I've read as many posts as I can find, and I have the following question for those mounting an ECP with unistrut.
I don't have a bracket, so how do I mount the lower piece of unistrut to the projector?
I assume I can use threaded rod through the 4 holes on the bottom? What size are the threads? Course or fine?
My idea is to mount 2 pieces of unistrut (de-magnetized) to the projector from side to side, and use a piece of threaded rod to hang it from 2 pieces of strut mounted on the ceiling from front to back (leaving me some room for adjustment.
The threads on the ECP all seemed to refer to using the strut in conjunction with a bracket or make-shift wooden bracket. Any help is appreciated!
Patrick
Patrick
