I set up my projector temporarily in my living room today, and ran a long cable from my pc to the projector (since I dont have the pricey transcoder yet)... I projected about a 62" wide image, and went to town adjusting it. Blue has always been the hardest for me to focus, and today it just wouldnt focus well at all (compared to red & green). I did the mechanical adjustment (center focus & edge focus) and I also tried the focus controll on the bias board - still a little fuzzy - the lines are too wide in the test pattern, and the dots dont look very round. I cant make out any fungus - but maybe it has some that I just cant see? Maybe it also needs an astig adjustment?
My brightness and contrast controlls work fine, but when I went to adjust the others (tint, color, and detail) - I couldnt make any apparent difference when I adjusted them... Should I see a huge difference from one end of the scale to the other (I really couldnt see a difference), or is something wrong with my PJ?? What in particular should I look for??? The only thing that I found that was physically damaged was the 10pin (27k) resistor on the remote board RN4 (its split in half almost). There is a pic here: http://bugman.50megs.com/proj_images/bad_resistor.jpg Could that have anything to do with it? I will replace it once I find a place that has one...
--Eric
--Eric
