1 - 9 of 9 Posts
Hi everyone
I need some help with my htpc set-up as I've moved the computer away to another room and now use a long hdmi cable to my TV.
The tv is a ue55d8000 and i have a home theatre system attached to it via spdif out from TV to the unit. The home theatre system is a DAV-DZ860W it does not have hdmi in but has spdif and coax.
Previously the htpc was situated by the tv and a coax from the tv transferred audio while hdmi to the TV and this was great however the computers a bit noisy so I thought moving the computer would be the easiest/cheapest way of dealing with this. Knowing that hdmi is dvi+spdif i thought that I wouldn't need to worry about audio as my TV supports (ARC) or Dolby pass through.
However the computer, running windows 7, does not allow me to send 5.1 over hdmi to the tv as it assumes the tv has only 2 speakers. After some investigating i realised i need to do an edid override and found an inf file here . Now with this installed I get dts and 5.1 through to the surround sound in media player classic however if I try to load a bluray it crashes TMT5.
I have a feeling it has to do with the edid file being slightly different to the one for my TV but I'm not sure and i was hoping somebody here could help me out.
I have my monitor info below incase it is needed for more detail or anything like that.
I would like to thank you in advance for any help/
Monitor info (Click to show) Monitor
  Model name............... SAMSUNG
  Manufacturer............. Samsung
  Plug and Play ID......... SAM07C5
  Serial number............ 1
  Manufacture date......... 2010, ISO week 46
  Filter driver............ None
  EDID revision............ 1.3
  Input signal type........ Digital
  Color bit depth.......... Undefined
  Display type............. RGB color
  Screen size.............. 1210 x 680 mm (54.6 in)
  Power management......... Not supported
  Extension blocs.......... 1 (CEA-EXT)
  DDC/CI................... Not supported
Color characteristics
  Default color space...... Non-sRGB
  Display gamma............ 2.20
  Red chromaticity......... Rx 0.640 - Ry 0.330
  Green chromaticity....... Gx 0.300 - Gy 0.600
  Blue chromaticity........ Bx 0.150 - By 0.060
  White point (default).... Wx 0.313 - Wy 0.329
  Additional descriptors... None
Timing characteristics
  Horizontal scan range.... 26-81kHz
  Vertical scan range...... 24-75Hz
  Video bandwidth.......... 230MHz
  CVT standard............. Not supported
  GTF standard............. Not supported
  Preferred timing......... Yes
  Native/preferred timing.. 1920x1080p at 60Hz (16:9)
    Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
  Detailed timing #1....... 1360x768p at 60Hz (16:9)
    Modeline............... "1360x768" 85.500 1360 1424 1536 1792 768 771 777 795 +hsync +vsync
Standard timings supported
     720 x  400p at  70Hz - IBM VGA
     640 x  480p at  60Hz - IBM VGA
     640 x  480p at  67Hz - Apple Mac II
     640 x  480p at  72Hz - VESA
     640 x  480p at  75Hz - VESA
     800 x  600p at  60Hz - VESA
     800 x  600p at  72Hz - VESA
     800 x  600p at  75Hz - VESA
     832 x  624p at  75Hz - Apple Mac II
    1024 x  768p at  60Hz - VESA
    1024 x  768p at  70Hz - VESA
    1024 x  768p at  75Hz - VESA
    1280 x 1024p at  75Hz - VESA
    1152 x  870p at  75Hz - Apple Mac II
    1152 x  864p at  75Hz - VESA STD
    1280 x  800p at  60Hz - VESA STD
    1280 x  960p at  60Hz - VESA STD
    1280 x 1024p at  60Hz - VESA STD
    1440 x  900p at  60Hz - VESA STD
    1440 x  900p at  75Hz - VESA STD
    1680 x 1050p at  60Hz - VESA STD
    1600 x 1200p at  60Hz - VESA STD
EIA/CEA-861 Information
  Revision number.......... 3
  IT underscan............. Supported
  Basic audio.............. Supported
  YCbCr 4:4:4.............. Supported
  YCbCr 4:2:2.............. Supported
  Native formats........... 1
  Detailed timing #1....... 1920x1080p at 50Hz (16:9)
    Modeline............... "1920x1080" 148.500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
  Detailed timing #2....... 1280x720p at 50Hz (16:9)
    Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
  Detailed timing #3....... 1920x1080i at 50Hz (16:9)
    Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
    1920 x 1080p at  60Hz - HDTV (16:9, 1:1) [Native]
    1920 x 1080p at  50Hz - HDTV (16:9, 1:1)
    1280 x  720p at  60Hz - HDTV (16:9, 1:1)
    1280 x  720p at  50Hz - HDTV (16:9, 1:1)
    1920 x 1080i at  60Hz - HDTV (16:9, 1:1)
    1920 x 1080i at  50Hz - HDTV (16:9, 1:1)
     720 x  480p at  60Hz - EDTV (16:9, 32:27)
     720 x  576p at  50Hz - EDTV (16:9, 64:45)
    1920 x 1080p at  24Hz - HDTV (16:9, 1:1)
    1920 x 1080p at  25Hz - HDTV (16:9, 1:1)
    1920 x 1080p at  30Hz - HDTV (16:9, 1:1)
    NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
  LPCM    2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
  Channel configuration.... 2.0
  Front left/right......... Yes
  Front LFE................ No
  Front center............. No
  Rear left/right.......... No
  Rear center.............. No
  Front left/right center.. No
  Rear left/right center... No
  Rear LFE................. No
CE video capability data
  CE scan behavior......... Supports overscan and underscan
  IT scan behavior......... Supports overscan and underscan
  PT scan behavior......... Not supported
  RGB quantization range... Not supported
  YCC quantization range... Not supported
CE colorimetry data
  xvYCC709 support......... Yes
  xvYCC601 support......... Yes
  sYCC601 support.......... No
  AdobeYCC601 support...... No
  AdobeRGB support......... No
  Metadata profile flags... 0x01
CE vendor specific data (VSDB)
  IEEE registration number. 0x000C03
  CEC physical address..... 4.0.0.0
  Supports AI (ACP, ISRC).. Yes
  Supports 48bpp........... No
  Supports 36bpp........... Yes
  Supports 30bpp........... Yes
  Supports YCbCr 4:4:4..... Yes
  Supports dual-link DVI... No
  Maximum TMDS clock....... 225MHz
  Audio/video latency (p).. n/a
  Audio/video latency (i).. n/a
  HDMI video capabilities.. Yes
  EDID screen size......... Rounded to nearest cm
  3D structures supported.. Top-and-bottom, Side-by-side w. horizontal sub-sampling
  3D formats supported..... Mandatory formats plus some primary VICs
  Data payload............. 030C004000B82D20D0080140073F405090A0
Report information
  Date generated........... 05/03/2014
  Software revision........ 2.60.0.972
  Data source.............. Real-time 0x0051
  Operating system......... 6.1.7601.2.Service Pack 1
Raw data
  00,FF,FF,FF,FF,FF,FF,00,4C,2D,C5,07,01,00,00,00,2E,14,01,03,80,79,44,78,0A,EE,91,A3,54,4C,99,26,
  0F,50,54,BD,EF,80,71,4F,81,00,81,40,81,80,95,00,95,0F,B3,00,A9,40,02,3A,80,18,71,38,2D,40,58,2C,
  45,00,A0,5A,00,00,00,1E,66,21,50,B0,51,00,1B,30,40,70,36,00,A0,5A,00,00,00,1E,00,00,00,FD,00,18,
  4B,1A,51,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,41,4D,53,55,4E,47,0A,20,20,20,20,20,01,26,
  02,03,32,F1,4B,90,1F,04,13,05,14,03,12,20,21,22,23,09,07,07,83,01,00,00,E2,00,0F,E3,05,03,01,72,
  03,0C,00,40,00,B8,2D,20,D0,08,01,40,07,3F,40,50,90,A0,02,3A,80,D0,72,38,2D,40,10,2C,45,80,A0,5A,
  00,00,00,1E,01,1D,00,BC,52,D0,1E,20,B8,28,55,40,A0,5A,00,00,00,1E,01,1D,80,D0,72,1C,16,20,10,2C,
  25,80,A0,5A,00,00,00,9E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,88
Discussion Starter · #3 ·
Originally Posted by Sammy2  /t/1521169/edid-override-help#post_24444594
How long is long and what specific cable are you using?
Thanks for the reply. I've currently move the pc back next to the TV to ensure its not the hdmi cable and am using a 2m cable however the long hdmi cable is 10M and is this one
Does that cable have Redmere technology? 30m is quite long to pass high speed HDMI without it.
Discussion Starter · #5 ·
Sorry I've never heard of Redmere technology and the HDMI cable is only 10m. I'm quite confused?
Sorry. I was converting meters to approximate feet.
At any rate, anything over 8 meters is considered too long for regular cable so you would need a RedMere Cable for it.
Discussion Starter · #7 ·
Oh okay. I understand and will look into that. But if im also using a 2m cable and there's still no bitstreaming, do you know how I can make it work?
OK. So 5.1 never worked before. Have yu considered upgrading your AVR? Maybe your TV is nit capable of passing 5.1 through to your AVR.
Discussion Starter · #9 ·
I have thought about upgrading the avr with one that has hdmi in but i would rather not spend any extra money. I know that the tv is capable as the passthrough worked in mpc with this edid inf .
Thanks for the fast response and help btw.
1 - 9 of 9 Posts
