Status
Not open for further replies.
1 - 4 of 4 Posts
What is the difference between edtv and a hd monitor and a hdtv?
I am looking to purchase a tv for under 2000 until Im finished my front projector theater and I just wanted to understand what I was purchasing
Comcast HD will usually give you a set top box which has the tuner in it. If you are going to use a comcast box, you probably don't need an HDTV with a built-in tuner.
1 - 4 of 4 Posts
Status
