New from ELAC is the Debut 2.0 Series of speakers. This is a total refresh of the entire Debut lineup that is a top to bottom redesign, with new drivers, cabinets and crossovers. The new models are the F6.2 tower, F5.2 tower, B6.2 bookshelf, B5.2 bookshelf, C6.2 center, C5.2 center, A4.2 Atmos speaker, OW4.2 on-wall speaker and SUB3010 subwoofer.
The all-new designs have a number of things in common. There's a new tweeter that's mounted in a wide dispersion waveguide. This is a silk dome tweeter that uses a wide-roll surround and has a frequency response of up to 35,000 Hz. The woofers have a new shape to the cone that ELAC says improves stiffness and damping. And this series features new larger cabinets that incorporate internal bracing. Plus, the tuned bass ports are now located on the front of the center channel and bookshelf models, for easier placement.
Here's some more info on this exciting new series of speakers from ELAC:
F6.2 Tower
This is the top-of-the-line in the new Debut 2.0 series. The F6.2 is a 2-way bass reflex speaker with the following specs:
Frequency Response: 39Hz – 35,000Hz
Nominal Impedance: 6 ohms
Sensitivity: 87db @2.83v/1m
Crossover Frequency: 90Hz/2200Hz
Max Power Input: 140 watts
Tweeter: 1″ cloth dome
Woofer: Triple 6.5″ aramid fiber
Cabinet Finish: Black ash vinyl
Port: 3X dual-flared
Binding Posts: 5 -way metal
Dimensions: 7.69″ (W) x 43.18″ (H) x 10.55″ (D)
Weight: 43.9 lb / 19.9 kg
F5.2 Tower
The F5.2 tower is more compact 2-way floorstander with smaller woofer than the similar F6.2 model. Here are the specs:
Frequency Response: 42Hz – 35,000Hz
Sensitivity: 86db @2.83v/1m
Woofer: Triple 5.25″ aramid fiber
Binding Posts: 5-way Metal
Dimensions: 7.09″ (W) x 40″ (H) x 9.21″ (D)
Weight: 34.4 lb / 15.6 kg
B6.2 Bookshelf
An update to the Debut B6, this model is sure to be one of the most intriguing budget/performance speakers of the year. Here's the specs:
Frequency Response: 44Hz – 35,000Hz
Crossover Frequency: 2200Hz
Max Power Input: 120 watts
Woofer: 6.5″ aramid fiber
Port: Front dual-flared
Binding Posts: 5-way metal
Dimensions : 7.69″ (W) x 14.76″ (H) x 10.55″ (D)
Weight: 16.3 lb / 7.4 kg
B5.2 Bookshelf
The compact Debut B5.2 is the sequel to the well-regarded Debut B5, this model is sure to be one of the most intriguing budget/performance speakers of the year. Here's the specs:
Frequency Response: 46Hz – 35,000Hz
Woofer: 5.25″ aramid fiber
Dimensions: 7.09″ (W) x 13.43″ (D) x 9.21″ (H)
Weight: 13.0 lb / 5.9 kb
C6.2 Center
A new center channel that's designed to keep up with the T6.2 towers and any other Debut 2.0 speaker, this model features dual 6.5" woofers. The new, dual front-mounted ports reduce or resolve some placement issues with rear ports. The specs are:
Frequency Response: 55Hz – 35,000Hz
Nominal Impedance: 8 ohms
Sensitivity: 88db @2.83v/1m
Woofer: Dual 6.5″ aramid fiber
Port: 2X Front dual-flared
Dimensions: 23.35″ (W) x 7.61″ (H) x 10.55″ (D)
Weight: 25.4 lb / 11.5 kg
C5.2 Center
The Debut C5.2 center channel offers a more compact and affordable option versus the Debut C6.2. This model features dual 5.25" woofers and the new, dual front-mounted ports, which mitigate some placement issues with rear ports. The specs are:
Woofer: Dual 5.25″ aramid fiber
Port: 2X dual-flared
Dimensions: 21.25″ (W) x 7.09″ (H) x 8.62″ (D)
Weight: 18.3 lb / 8.3 kb
A4.2 Dolby Atmos Modules
The Debut 2.0 Series offers Atmos compatibility with the A4.2 module. It's an aesthetic match for the rest of the series and sits on top of speakers. Reflected sound from the ceiling adds elevation effects to the home theater experience for true 3D immersive audio. Specs are as follows:
Speaker type: Coaxial, sealed
Tweeter: 1 x 0.5" polymer dome
Woofer: 1 x 4" woven aramid-fiber cone
Crossover Frequency: 5000 Hz
Frequency Response: 180Hz to 20,000Hz
Sensitivity: 85 dB at 2.83 v/1m
Recommended Amplifier Power: 20 to 80 watts per channel
Nominal/Peak Power Handling: 50 / 80 watts per channel
Nominal Impedance: 6 ohms; minimum 5.1 ohms
Binding posts: 5-way metal
Cabinet finishes: Black ash vinyl
Dimensions: 7.09″ (W) x 4.92″ (H) x 9.21″ (D)
Weight: 5.5 lb / 2.5 kg
OW4.2 On-Wall
ELAC addresses the needs of home theater enthusiasts looking for a compact on-wall satellite speaker solution that cleverly incorporates dual down-firing ports to stay under 4" deep and allow for gapless mounting. Check out the specifications:
Frequency Response: 70Hz – 35000Hz
Crossover Frequency: 2500Hz
Max Power Input: 80 watts
Woofer: 4″ aramid fiber
Port: 2X down-firing dual-flared
Dimensions: 7.87″ (W) x 12.76″ (H) x 3.94″ (D)
Weight: 7.9 lb / 3.6 kg
SUB3010 10" Subwoofer
A new sub to go with the rest of the Debut 2.0 series, the SUB 3010 is a 200 watt RMS 10-incher with a front-firing active driver and a down-firing passive radiator. It offers app-based control that incorporates DSP programming  and auto-EQ capabilities. Here are the specs:
Woofer: 1 x 10-inch high-excursion doped paper cone
Passive Radiator: 1 x 10-inch high-excursion doped paper cone
Frequency Response: 28 to 150 Hz
Crossover Rrequency: 50 to 150 Hz, continuously adjustable
Amplifier Type: BASH-tracking
Maximum Amplifier Power: 400 watts peak / 200 watts RMS
Standby Power Consumption: 0.5 Watt
Inputs: L/R/LFE RCA
Dimensions: 13.5″ (W) x 14.33″ (H) x 13.5″ (D)
Net weight: 32.1 lb / 14.6 kg
We are committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works  here .
