Status
Not open for further replies.
1 - 1 of 1 Posts
Ok, I may have found a count method for doing electric focusing, independed of optical focus.
Put on the dot pattern, look straight into the lens and then do electric focus.
As you look straight into the lens the dots are so large that optical focus doesn't really mather.
ofcource the best way is taking the lenses off, but then you can't do the optical hocus focus trick.
1 - 1 of 1 Posts
Status
