My current system is 5.2 Currently advancing toward 5.2.4 Currently Dolby 'Almost' hoping to be soon Dolby 'Atmos'.
My NAD processor is eligible for a additional card that will extract four additional height channels. I bought the $600 card and are awaiting installation. I have a ROTEL 5 channel amplifier that has worked perfectly for years. It's connected by 5 RCA cables from my NAD processor. This Rotel is actually housed in my basement as it's always cooler in my basement and I never wanted to hear the additional fans that I but on top of it. (4K blu-ray player is also in the basement connected by fiber based HDMI cables)
While shopping for an additional amp for the height channels, I discovered that these external amps use a LOT of electricity. The current amp I am shopping for is an Outlaw 5 channel amp and I discovered that it lists it's electrical consumption at 1500 watts!!!!! WOW!!!!
My current Rotel RMB-1075 is rated at 800 watts power consumption.
I'm afraid that I may blow a standard 15 amp circuit breaker when both amps are hooked up to the same power source. HOW DO I OVERCOME THIS!!!!!!! If I run both amps together on the same circuit, I will pop the circuit breaker. I also have the NAD processor and the TV as well as one subwoofer all on the same AC circuit to prevent ground loops and hum. Surely there are a loot of guys that run two separate power amps. How do you manage power consumption?? This will become an issue soon as soon as I install the new power amp. I can already see the AC circuit breaker popping the first night after I add the 2nd power amp.
Thanks --Greg--
Thanks --Greg--
