Elite Cintension2 Problems
960 Views 1 Reply 2 Participants Last post by  enricoclaudio
I received and installed my 92" Cinetension2 screen today. When I extended the screen the first time I saw what appears to be roller marks or small wrinkles throughout the surface. This screen had a build date of 2007 so it's been sitting for a long while which is probably the source of the problem. I have the screen lowered hoping that these wrinkles will work themselves out in time. Otherwise, I have to try and return it.
I tried to get a shot of the wrinkles but they are very small.
See less See more
1 - 2 of 2 Posts
Mine is perfect flat (only a minimal small wave in the lower right corner black area). Is a Cinetension 2 100" PowerGain surface. In some scenes you can see horizontal lines in the screen surface, this lines appears to be roller marks and is normal in pull down screens (electric or manual). Is this problems cause distraction, returns to the factory and claim a replace.
http://www.avsforum.com/avs-vb/showt...8#post14057388
Bye
1 - 2 of 2 Posts
