Elunevision Tab Tensioned Motorized Screen Trigger Issue Help ?
3573 Views 4 Replies 4 Participants Last post by  Reuben Chin
Any one that have   Elunevision  Titan Tab Tensioned Motorize Screen and using the trigger function .
Can you please elaborate  on it ,i have 120" motorized tab tension  at home and trying to
mono jack from Panasonic Projector to it but no go , it's seem to go half way and in angle  which don't make sense so prevent any problem i email elunevion from their website and the answer didn't make sense to me ( Connect is mini barrel connector ,id is 1.3mm,od is 3.5mm ) i have all sort of adapter 2.5 mm ,3.5mm kit stereo or mono none of them go thru  just half way in .
Anyone one else having this issue.or any screen recommendation with 12V Trigger  that work flawlessly ,i'm still under warranty can take it back if can use the function.
Leonsmalto
Edmonton , AB
See less See more
1 - 5 of 5 Posts
I have an Elunevision Tab Tensioned Motorized screen with a Panasonic projector. I connected the remote trigger to a femal to male mono mini plug extension cable and plugged that into the projector. It works flawlessly. The projector has a built in delay that doesn't send the 'down' signal until it has warmed up, about 45 seconds or so. When shutting off it sends the 'up' signal immediately.
I have 106" and trigger from them, doesnt work all the time, at times just goes up others the other way around. Gave up on it
just use remote which works all the time.
See less See more
Having the same problems here...
I have a 106 Motorized Tension screen.
Thinking I had a dud for a 25ft 3.55mm cable, but now I read this thread and think otherwise!
I'm looking for any solutions and will likely call / email Elunevision to help resolve this. The whole idea of going this route was to have the WOW factor... I'm a little disappointed right now but I'm hoping for the best.
If anyone has any update please send me an updated thread or note.
Cheers,
RC:)
Cheers,
RC:)
1 - 5 of 5 Posts
