Emotiva Reference MMC-1 AV Processor Review
5345 Views 0 Replies 1 Participant Last post by  MrNomas
What do you get when you cut the price of the DMC-1 by almost 67% off its original retail price, upgrade the cosmetics and add HDMI functionality? The Reference Theater Series MMC-1. For those seeking solid performance, with a high WAF, the Emotiva MMC-1 A/V processor paired with the matching IPS-1 7CH power amp is a killer combo. Combine this with Emotiva's excellent customer support and aggressive tradeup deal on their processors, and you've choice for your next separates solution just got that much easier.
Pros
  • Sounds as good as it looks
  • Super easy operation and setup
  • High Value
Cons
  • Lacks some of the most modern processor features as noted in our DMC-1 review
  • Average noise performance on some tests (see notes)
Read the Full Review
See less See more
1 - 1 of 1 Posts
1 - 1 of 1 Posts
