Hi all
I use laptop Asus k72jr-ty042 as HTPC. It has i3 350M cpu, ATI 5470 vga and HDMI out. Usually I play 1080p BR-RIP on it with Potplayer (easy setup for 3D playback) and everything works fine and CPU load is below 20-30%
Recently I've downloaded IMAX DEEP SEA 3D (2006) UNTOUCHED .iso image with MPEG-4 AVC Video, 1080p / 23.976 fps / 16:9 / High Profile 4.1 parameters and which I don't know how to play on Potplayer in 3D so I've used Cyberlink Powerdvd 14 for playback because I've read that it plays 3D BR images. And it does.
Problem is that when I play it in 3D, after few seconds the CPU hits the sky with 100% load and stays there (around 95-100%)
So I thought that ATI 5470 has hardware decoder for BR HD video and it seams it's called Unified Video Decode, version 2 (UVD-2) and also it seams it has to be supported in PowerDVD because UVD-3 is supported from PDVD 12 (i have 14)
So could anyone explain to me why it doesn't work and how can I get it to work? all in all, i want to watch 3D BR .iso so any suggestion is welcome
BTW i noticed that Cyberlink has better 3D picture than Potplayer. I watched Hobbit the other day and in PDVD it is at least one grade better than in Potplayer. And idea why?
