Status
Not open for further replies.
1 - 2 of 2 Posts
Does anyone know anything about this subwoofer? I can get a brand new one for $500 but I'm having trouble finding much on it in the way of reviews. Any insights, links to reviews, etc. would be greatly appreciated. Also, the model I'm looking at has a "-1" designation which leads me to believe that there may have been "-2", "-3", etc. models. Any information concerning differences in these models would also be appreciated.
That is a discontinued model from a few years back, I had one and its cousin from Mirage. I would say that it is basically the equivalent to the Velodyne SPL II series, with maybe a little more power. They are sealed subs with powerful amps, and a little EQ (Linkwitz Transform circuits), to make them relatively flat in-room. They can sound very good for both music and movies. If you want the reference levels in your home-theater set-up, one of these will most likely dissappoint. For $500, you did fairly well.
JP
1 - 2 of 2 Posts
Status
