1 - 4 of 4 Posts
Needing to buy some speaker mounts for Energy Take Classic speakers. Any suggestions on some wall mounts that get the job done pretty well and are economically priced?
 Monoprice has a few options . I personally prefer the ball joint type for unlimited angle placement. Ones that only tilt up and down are impossible to angle to the listener.
Originally Posted by Ben_Tech /forum/post/17020802
Something like the Sanus WMS5 should work well. The kit will mount all five speakers.
http://www.sanus.com/us/en/products/...ker-mount/WMS5
I just got these for a set of Energy Take speakers (which are still in shipping). Where does the speaker cable go with these mounts? Along the side of the extension arm? I always thought the wire ran through the mount, but there is no hole with these mounts. I'm sure I'm missing something, but it does not look like these mounts will cover the hole in my ceiling where the speaker wire comes through.
1 - 4 of 4 Posts
