1 - 3 of 3 Posts
Banned
it keeps cutting off several times an hour. i have to change inputs to another source then change it back for it to work again.
its been happening for the last few months but lately its cutting off more often.
im using a denon 1609 receiver. im thinking about running the audyssey again. any ideas?
What are your Audyssey settings now?
Try a different subwoofer cable?
turn the volume down on your sub and rerun Audyssey so that the sub channel level is a little higher.
Adjust the sub channel level maually on the receiver so that it is higher.
Get a Y adapter and connect to both red/white inputs on sub input. This will boost the incoming signal by 3db.
Banned
Discussion Starter · #3 ·
ill try replacing the cable first. it only happens on direct tv. i notice it happens more often watching tv food network than other channels. it doesnt happen with my dvd player or blu ray player though.
as far as that adapter. i dont think my sub has those left and right inputs. i bought it from costco and its a downfiring sub, supposedly the same one that comes with the take energy 5.1 speaker system. ill have to check when i get home. thanks
1 - 3 of 3 Posts
