Status
Not open for further replies.
1 - 3 of 3 Posts
Bought an electrohome 800915 ("enhanced pc interface") input card a week or so ago on e-bay... Dont really know why I bought it, just ended up with it. Looks new, but I havnt tested it out yet. Is this any better than the rgb input card I already have? If not, whats its value in working condition?
--Eric
Sir
The value is, uh, essentially nil unless you intend to display CGA or EGA, which are TTL-level signals (4 volt logic) versus 0.7 volt RGB.
If it has a 9 way 'D' type connector for the PC input - it's an EGA/CGA adaptor - Fine if you can find an EGA card for your PC... (EGA cards were last sold to Noah, for fitting to his home cinima on the Ark...)
1 - 3 of 3 Posts
Status
