1 - 20 of 25 Posts
Hi guys ... so ... i am ditching my cable company .... enough!
Question........
I now have an antenna connected to TV. How do I get the TV sound to come out of Receiver and thus my home theater?
My TV is Panasonic TH50PX60U (see pic of back of it I attached here) and my receiver is Denon 4311.
Question #2 is ..... what other equipment should I add to this set up to improve my "non cable tv" TV programming? HD converter or something?
thank you
Your TV has a built-in tuner so you shouldn't need any converters or additional equipment besides the antenna. With broadcasts being digital now, they should be clear and shouldn't need any improvement. If you're having pixelation issues or don't receive many channels, your antenna may not be very good quality. If it is a directional antenna, it also may be pointed in the wrong direction. You can use the link below and type in your zip code or address and it will tell you where the towers that transmit the signals are so you know where to 'aim' for signal
http://www.antennaweb.org/Address.aspx
Discussion Starter · #4 ·
Originally Posted by grasshoppers  /t/1520137/enough-of-cable-bills-no...from-tv-to-receiver-please-help#post_24416994
1) use the digital audio out jack on the back of the TV.
It's called a Toslink cable. Connected into back of the AVR.
http://www.amazon.com/Mediabridge-Toslink-Cable-Feet-Optical/dp/B004LSNF04
2) can't answer, I live in the sticks, my only option is Satellite .
where is my Optical input on TV? I can't seem to find it on the back of the TV.
thanks
Originally Posted by Pianist718  /t/1520137/enough-of-cable-bills-no...from-tv-to-receiver-please-help#post_24417691
thanks
It's an optical OUTPUT....out to your AVR.
It is to the left of all of the other jacks,right next to "ANT" jack.
  • Like
Reactions: old corps
Discussion Starter · #7 ·
ok, so now, on the receiver that optical cable goes into (IN) Optical TV) right?
so to get that input to work, on remote what should be selected? to indicate to receiver to pull sound from that input.
thank you
Originally Posted by Pianist718  /t/1520137/enough-of-cable-bills-no...from-tv-to-receiver-please-help#post_24417738
thank you
Correct. I'm not familiar with your remote but there should be TV button for audio...........
Ed
thank you
That's were the fun begins!
You may have to go into your AVR menu
And "assign" to optical input to the tv button/setting. Most AVR's assume
That you are going to use HDMI.
Originally Posted by grasshoppers  /t/1520137/enough-of-cable-bills-no...from-tv-to-receiver-please-help#post_24417753
+1
I'm guessing it might say TV on the remote since it appears that is the default assignment on the receiver.
Ed
Discussion Starter · #11 ·
well, I'll find out tonight :)
I feel bad I didn't get rid of cable a long time ago. But when they increased my service from $100 to $140 with absolutely no way to get a discount, it was enough for me
Another thing to bare in mind is that some TVs only process 5.1 channel audio from OTA sources. So if you have a smart TV, or Roku/Apple TV going into the TV via HDMI, you may not get multi channel sound from that source. Just an FYI.
I've been a cord cutter for years and it only gets better. The only live content I watch is football...so I get that in high def with multichannel audio right over the air. All other content is online. It's really liberating and saves a ton of money.
Originally Posted by wvu80  /t/1520137/enough-of-cable-bills-no...from-tv-to-receiver-please-help#post_24417960
I'm assuming your HDTV does not have HDMI OUT (or HDMI return)
The easy way to get sound from your TV to your AVR is to use the TV headphone jack (or audio OUT) and connect it on the AVR side with RCA plugs to TV/DVD IN.
Your cable should look like this: http://www.parts-express.com/35mm-slim-plug-male-to-2-x-rca-male-adapter-cable-5-ft--240-065
If your TV has the Optical OUT, then I agree with others, that would be your best option.
The only option that will get him multichannel audio is optical. I don't know of many (if any) TVs that have HDMI out, and the other options you mentioned only provide stereo output.
Discussion Starter · #15 ·
If you have internet to your house, (I'm guessing you do, since you're on this forum), you should get a Roku. Get the cheapest one - it only outputs 720p video, but you have a 720p TV, so it's perfect. They're only $49.99, and they work great. If you have a wireless router in your house to use laptops, etc, it's a snap to hook the Roku up to your wifi, and you can stream the dozens, hundreds, of free internet video sources in 720p hd to your TV. A Netflix online subscription is still only $8/mth I think, and gives you access to a LOT of content. Hell, they just added the last series of Breaking Bad, so right there it's worth it. If you don't have a wireless router, you should get one - get a refurb from newegg.com or somewhere, it'll only be about $29.99, and you're off to the races. Youtube is fantastic these days btw - it's not all just kittens playing the piano - there are channels dedicated to a multitude of things. I watch full length rugby matches from Europe and Australia/NZ for instance. It's free. Pandora is on the newest high end Rokus, but not the lower end models, (I think). I set my 85yr old mother in law up with exactly this combination two years ago, and she's now a Netflix pro - loves it.
BTW - I still have almost that exact TV - I have the TH50PX75U - it's still got a great picture, but lightning took out its HDMI port
Premium Member
Originally Posted by Novum Dives  /t/1520137/enough-of-cable-bills-no...v-to-receiver-please-help/0_100#post_24417970
He was referring to HDMI(ARC) that is featured on most every HDMI 1.4 TV going back 3 years; however the OP's TV pre-dates HDMI(ARC) and although his AVR has the feature, unless the TV does as well, the audio cannot be passed back to the AVR over the HDMI cable that connects them. Also note that although a couple of years ago it was true that HDMI(ARC) could only pass stereo PCM 2.0 audio, many current 2013 models will actually pass DD 5.1 or DD+ (Netfflix) via the HDMI(ARC) connection.
Originally Posted by Novum Dives  /t/1520137/enough-of-cable-bills-no...tv-to-receiver-please-help/0_50#post_24417970
Thanks, it's called ARC (audio return channel) and I thought I was going crazy to mention it! I was sure I knew what it was, until you challenged the idea, then I wasn't sure.
http://hdguru.com/what-is-hdmi-arc-and-what-does-it-do-for-your-hdtv/
Now I'm sure.
Edit: Sorry Mr. Smoothie, I should have read the entire thread instead of responding prematurely. Your explanation was much better than mine.
Banned
Originally Posted by Pianist718  /t/1520137/enough-of-cable-bills-no...from-tv-to-receiver-please-help#post_24418300
any benefit from using....
Viewtv At-163 ATSC Digital TV Converter Box and Media Player w/ Recording PVR Function / HDMI Out / Coaxial Out / Composite Out / USB Input
http://www.amazon.com/Viewtv-Converter-Recording-Function-Composite/dp/B00GGVPKKC/ref=sr_1_4?ie=UTF8&qid=1393538703&sr=8-4&keywords=hdtv+dvr
The documentation is skimpy, but in general this class of device is stereo-only, no multichannel.
Discussion Starter · #20 ·
So, Optical cable made everything work fine. I do get 5.1 channels in Dolby from my Antenna TV watching.
only issue is ... most channels display in 720p and only channel 4 and 2 are in 1080i.
how do I better this?
also, seems like when I walk by the antenna, picture gets lost or pixalated. Will a better quality antenna do a better job? I am awaiting a delivery of my Mohu Curve 30 Designer HDTV Antenna tomorrow. For now, using Radio Shacks $10 antenna.
and last but not least ............. reprogrammed my universal remote Harmony to function with my new TV watching .... everything works fine, BUT ... i still can't make universal remote change channels of the TV. Still have to use my TV remote to do this.
1 - 20 of 25 Posts
