1 - 5 of 5 Posts
· Premium Member
I am planning on mounting an LCD flat panel above a fireplace. The fireplace has an oversized firebox (31" high) so I expect the bottom of the LCD will only be 12" to 18" above the firebox. I have looked on Sony, Samsung, and Pioneer's web sites and I do not find any environment specifications (max tempature). The fireplace vendor has measured that a spot 12" from the top of the firebox and 7" out from the wall is consistently 97 degress farenheit. I have two questions:
1) How high do people typically hang their projectors above the fireplace.
2) Does anybody know where I can get the environmental specifications for flat panels?
Thx
Bryan
· Registered
Typically people avoid this, not just for the heat issues, but also because it places the display too high on the wall resulting in an uncomfortable viewing experience.
· Registered
I have mine over the fireplace. a mantel that catches most of the heat is definately a plus. As far as viewing height, be sure to use a mounting bracket that allows you to tilt the display down toward the viewing location.
· Registered
The other destroyer of electronics is very present when hanging a TV over the fireplace. Soot/Dust/smoke/etc. I almost had a plasma slide out of my hands when i tried to take it off the mount over a fireplace once. Owner of the home damn near had a heart attack. When i had the set opened up (maintenance, blew a fuse on the power supply), it was just oily and black inside on the sheet metal. The guy had also noticed the picture get a little dimmer too, windex'd the screen, YUK. Now, he had a little ventilation issue, but i've seen buildup on ALL sets over a fireplace (woodburning that is, gas is pretty clean, imagine that.
1 - 5 of 5 Posts
