1 - 6 of 6 Posts
Premium Member
Discussion Starter #1
Anyone know of a horizontal wall mount platform for the Epson 4000 projector
Premium Member
Discussion Starter #3
For a solid support....Target Turntable wall mounts work great.... this one's a vintage model supporting my 4030 but current ones are also big enough to accommodate the current Epson 4000 and 5000 series....prices have recently doubled but used ones popup once in awhile for $100 or so.
https://www.hifishark.com/search?q=target+turntable+wall+mount
http://www.targetaudioproducts.com/home.html
Thank you very much for the website, unfortunately the rack isn't available now.:)
I would check Wayfair for some reasonably priced wall shelves if you are looking for something 'slick'...
https://www.wayfair.com/furniture/pdp/omnimount-wall-panel-om0546.html
https://www.wayfair.com/furniture/sbs/av-component-shelving-c414573-q~wall+mount+av+component+shelf.html?curpage=2
Amazon... of course...
https://www.amazon.com/Elitech-EW1BC-Projector-Wall-Mount/dp/B00DR13JUC/ref=sr_1_17_sspa
But, you can get shelf hardware from Home Depot for under $20 (or so) and spray paint it all black and call it done.
If you are looking for a full featured wall mount, try something like this:
https://www.amazon.com/dp/B07H1D8F87
You do have a ton of options depending on what exactly you are trying to achieve.
1 - 6 of 6 Posts
