1 - 3 of 3 Posts
I'm using a Carada BW 126" Diagonal 16:9 screen. So about 110" wide. I would like to place my first row somewhere between 12-13' from the screen.
Do I need to be worried about SDE at this distance with this projector?
Not in the slightest. You'd have to be 5-6 feet away to even notice the pixels.
With a 118 inch 16x9 screen I noticed noise in solid areas of the image from 12 feet that isn't there with a Sony VPL-HW15. It doesn't jump out at you but the image simply isn't as smooth/clean.
1 - 3 of 3 Posts
